Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Reformat Report Tables
• Turn a Report Table Into a Matrix
JMP.com/help
You can create a JMP matrix from a report table. For example, when working with JMP Scripting Language (JSL), you might want to access a report’s table that has been stored into a JSL variable. Or, you might want to store a report table’s values into a table property as either a table property or as a JSL assignment, which is stored within the data table and is accessible via a script or the Formula Editor.
To store a table in matrix form into a global variable, into a table property, or into a table property as an assignment:
Right-click anywhere in a report table.
Select
Make into Matrix
In the window that appears, tell JMP how you want to store the table.
(Optional) Rename the variable or property by entering a new name into the box beside Name.
Help created on 3/19/2020
