Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Prospective Sample Size and Power
• Two Sample Means Calculator
JMP.com/help
Use the Two Sample Means calculator to evaluate sample size for a hypothesis test about two means. Explore questions such as how large a treatment effect is detectable for a given sample size, significance level, desired power, and assumed variability in the data. Sample size and power are associated with the following hypothesis test:
versus the two-sided alternative:
where
μ
1
and
μ
2
are the true means of the two populations. It is assumed that the populations of interest are normally distributed and that you want to detect a difference of
δ
between the means.
Help created on 3/19/2020
