Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Essential Graphing
Bubble Plots
Interact with the Bubble Plot
• Use the Brush Tool
JMP.com/help
Use the Brush Tool
Use the brush tool
to temporarily select bubbles and obtain more information about the selected bubbles. When you select bubbles with the brush tool, the corresponding rows are highlighted in the associated data table.
Note:
For a more granular examination of the highlighted rows, use the
Tables > Subset
command or the Row Editor. See
Create a Subset Data Table
in the
Using JMP
book.
Help created on 3/19/2020
