Discovering JMP
Using JMP
Basic Analysis
Essential Graphing
Profilers
Design of Experiments Guide
Fitting Linear Models
Multivariate Methods
Quality and Process Methods
Consumer Research
Scripting Guide
JSL Syntax Reference
JMP iPad Help
JMP Interactive HTML
Capabilities Index
JMP 13.2 Online Documentation
Using JMP
JMP Reports
Navigate Reports
• Use the Hand Tool
JMP.com/help
Use the Hand Tool
Select the hand tool using the Tools > Grabber option. There are many functions that you can use with the hand tool (also known as the grabber tool) in a report. Here are some examples of how the hand behaves in graphs and plots:
On histograms, for continuous variables, use the hand tool to change the number of bars or to shift the boundaries of the bars.
In all report tables, use the hand tool to click and drag columns for rearranging.
Use the hand tool to change the displayed range of axis values. See
Scroll and Scale Axes
Help created on 3/19/2020
