Select Help > Sample Data Library and open Design Experiment/Wine Data.jmp.
Click Run.
Figure A.29 Profiler with Original Value Ordering
Notice that the values for De-Stem and Filtering appear in the order No followed by Yes. You want to reverse these, so that the Yes level appears first.
In the data table, click the asterisk next to De-Stem in the columns panel and select Value Ordering.
6.
Click Reverse.
7.
8.
Click the asterisk next to Filtering in the columns panel and select Value Ordering.
9.
Click Reverse.
10.
12.
Click Run.
Figure A.30 Profiler with New Value Ordering
The levels for De-Stem and Filtering now appear in the order Yes followed by No.
13.
Close the Wine Data.jmp sample data table without saving the changes.
Help created on 3/19/2020
