Each platform has preferences configurable using File > Preferences > Platforms. Each platform’s options are scriptable. For detailed information about scripting platform preferences, refer to the JMP Scripting Index. In JMP, select Help > Scripting Index for details.
The following JSL option for Fit Distribution() is equivalent to the Make into Data Table option on the right-click menu for the Parameter Estimates table:
In Standard Least Squares, save prediction formulas as SQL expressions using Get SQL Prediction Expression(). For an example, see the JMP Scripting Index on the Help menu.
In a script, the Y responses are fit together by default. The model fits each Y using only those rows that are nonmissing for all of the Y variables. For example, a row that includes one or more missing Y values is excluded from the model. You can explicitly include Run( "Fit Together" ) in a script to get the same result.
If you include the Run( "Fit Separately" ) option, the model fits each Y using all rows that are nonmissing for that particular Y. For example, a row that includes one or more missing Y values is included in the model.
In JMP, the user is prompted to select Fit Together or Fit Separately when running the model. See the Standard Least Squares chapter in Fitting Linear Models for details about how missing Y values are handled.
The following options for Neural() are available only in JSL:
The following options for Partition() are available only in JSL:
The following options for Time Series() are available only in JSL:
The following option for Choice() is available only in JSL:
The following option for Control Chart() is available only in JSL:
