Publication date: 07/30/2020
Adjust the Axes
You can manually move or rescale the axis coordinates by clicking and dragging the axis. This option shows a different set of coordinates on the 3D scatterplot. It also lets you change the space displayed between the coordinates (or the coordinate scaling).
You can also specify axis properties by double-clicking the axis and modifying settings in the specifications window.
To Move the Coordinates on the Axis
1. Place your cursor over the middle of the axis.
2. Click and drag the axis.
To Modify Coordinate Scaling
1. Place your cursor over the end of the axis.
To Rescale an Axis Precisely
1. Place your cursor over the middle of the axis (the axis, not the label).
2. Double-click the axis.
3. Change the minimum and maximum coordinate values.
For more information about updating axes, see Customize Axes and Axis Labels in the Axis Settings Window and Customize Axes and Axis Labels Using the Pop-Up Menu in Using JMP.
