Publication date: 07/30/2020
Adjusted Inertia
The usual principal inertias of a Burt table constructed from m categorical variables in MCA are the eigenvalues uk from . These inertias provide a pessimistic indication of fit. Benzécri (1979) proposed the following inertia adjustment; it is also described by Greenacre (1984, p. 145):
for
This adjustment computes the percent of adjusted inertia relative to the sum of the adjusted inertias for all inertias greater than 1/m.
Greenacre (1984, p. 156) argues that the Benzécri adjustment overestimates the quality of fit. Greenacre proposes instead to compute the percentage of adjusted inertia relative to:
for all inertias greater than 1/m, where tr(D4u ) is the sum of squared inertias and nc is the total number of categories across the m variables.
