Essential Graphing > Scatterplot 3D > The Scatterplot 3D Report > Assign Colors and Markers to Data Points
Publication date: 07/30/2020
Each point in the 3D scatterplot corresponds to a row in the associated data table. To highlight points on the 3D scatterplot, you assign colors and markers to the points. The colors and markers are then displayed on the 3D scatterplot and in the data table.
When you click a point, the following items are selected:
the point in the 3D scatterplot
the corresponding row in the associated data table
the point in any other opened graphs, if applicable
To select one point, click the point.
To select several points, double-click the 3D scatterplot and drag the cursor over the points. A box is displayed to indicate which points are selected.
To deselect points, double-click the 3D scatterplot.
To assign a color or marker to selected data points, proceed as follows:
1. To assign a color to the selected point, select Rows > Colors and then select the color.
2. To assign a marker to the selected point, select Rows > Markers and then select the marker.
