Publication date: 07/30/2020
Cause and Effect Diagram Menu Options
The Cause and Effect Diagram red triangle menu contains the following options:
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
