Discovering JMP > Special Features > Change Preferences
Publication date: 07/30/2020
Change Preferences
You can change preferences in JMP using the Preferences window. To open the Preferences window, select File > Preferences (Windows) or JMP > Preferences (macOS).
Figure 8.6 Preferences Window
On the left side of the Preferences window is a list of Preference groups. On the right side of the window are all of the preferences that you can change for the selected category.
