Publication date: 07/30/2020
Change Table Names
A data table’s name appears at the top of its window, in the table panel, and on all related analysis reports. You can change a data table’s name in any of the following ways:
Select File > Save As and save as the new name.
In the table panel, click table name, type the new name, and then press the Enter key.
On Windows, select Window > Set Title.
