Publication date: 07/30/2020
Changing the View
One of the advantages of creating a 3-D scene is the ease that they can be viewed from different angles and positions. The Translate and Rotate commands let you set the position from which you view the scene.
In addition, you can use the ArcBall command to enable the user to change the viewing angle interactively.
