Publication date: 07/30/2020
Clustering Method
Hierarchical is the default clustering method, but the dialog enables you to switch to KMeans or Normal Mixtures. If you select KMeans or Normal Mixtures, when you click OK, a Control Panel appears where you can select any of the following as Method:
K-Means Clustering
See K Means Cluster.
Normal Mixtures
See Normal Mixtures.
Robust Normal Mixtures
See Normal Mixtures Report in the Normal Mixtures section.
Self Organizing Map
See Self Organizing Map in the K Means Cluster section.
