Design of Experiments Guide > Compare Designs > Compare Designs Window: Design Evaluation
Publication date: 07/30/2020
Power Analysis
Prediction Variance Profile
Fraction of Design Space Plot
Relative Estimation Efficiency
Alias Matrix Summary
Absolute Correlations
Design Diagnostics
Color Dashboard
Several of the Design Evaluation outlines show values colored according to a color bar. The colors are applied to diagnostic measures and they help you see which values (and designs) reflect good or bad behavior. You can edit the legend values to apply colors that reflect your definitions of good and bad behavior.
Figure 16.19 Color Dashboard
You can modify the color bar by selecting these two options in the red triangle menu for the outline or by right-clicking the color bar:
Show Legend Values
Shows or hides the values that appear under the color bar.
Edit Legend Values
Specify the values that define the colors.
