Discovering JMP > Visualize Your Data > Compare Multiple Variables
Publication date: 07/30/2020
Use multiple-variable graphs to visualize the relationships and patterns between two or more variables. This section covers the following graphs:
Table 4.1 Multiple-Variable Graphs
Scatterplots
Use scatterplots to compare two continuous variables.
Scatterplot Matrix
Use scatterplot matrices to compare several pairs of continuous variables.
Side-by-Side Box Plots
Use side-by-side box plots to compare one continuous and one categorical variable.
Variability Chart
Use variability charts to compare one continuous Y variable to one or more categorical X variables. Variability charts show differences in means and variability across several categorical X variables.
Graph Builder
Use Graph Builder to create and change graphs interactively.
Overlay Plots
Use overlay plots to compare one or more variables on the Y-axis to another variable on the X-axis. Overlay plots are especially useful if the X variable is a time variable, because you can compare how two or more variables change across time.
Bubble Plots
Bubble plots are specialized scatterplots that use color and bubble sizes to represent up to five variables at once. If one of your variables is a time variable, you can animate the plot to see your other variables change through time.
