JSL Syntax Reference > JSL Functions > Conditional and Logical Functions
Publication date: 07/30/2020
And(a, b)
a&b
Description
Logical And.
Returns
1 (true) if both a and b are true.
0 (false) if either a or b is false or if both a and b are false.
Missing if either a or b is a missing value or if both a and b are missing values.
Arguments
Two or more variables or expressions.
Notes
More than two arguments can be strung together. a&b returns 1 (true) only if all arguments evaluate to true.
AndMZ(a, b)
a:&b
Description
Returns the logical AND of all arguments. Missing values are treated as zeroes.
Returns
0 (false) if either a or b is a missing value or if both a and b are missing values.
Arguments
Notes
More than two arguments can be strung together. a:&b returns 1 (true) only if all arguments evaluate to true.
Break()
Description
Stops execution of a loop completely and continues to the statement following the loop.
Note
Break works with For and While loops, and also with For Each Row.
Choose(expr, r1, r2, r3, ..., rElse)
Description
Evaluates expr. If the value of expr is 1, r1 is returned; if 2, the value of r2 is returned, and so on. If no matches are found, the last argument (rElse) is returned.
Returns
The value whose index in the list of arguments matches expr, or the value of the last argument.
Arguments
expr
an expression or a value.
r1, r2, r3, ...
Continue()
Description
Ends the current iteration of a loop and begins the loop at the next iteration.
Note
Continue works with For and While loops, and also with For Each Row.
For(init, while, increment, body)
Description
Repeats the statement(s) in the body as long as the while condition is true. Init and increment control iterations.
Returns
Null.
Arguments
init
Initialization of loop control counter.
while
Condition for loop to continue or end. As long as the conditional statement while is true, the loop is iterated one more time. As soon as while is false, the loop is exited.
increment
Increments (or decrements) the loop counter after while is evaluated every time the loop is executed.
body
Any number of valid JSL expressions, glued together if there are more than one.
Example
mysum = 0; myprod = 1;
For( i = 1, i <= 10, i++, mysum += i; myprod *= i; );
Show( mysum, myprod );
mysum = 55;
myprod = 3628800;
For Each Row(<dt,> script)
Description
Repeats the script on each row of the data table.
Returns
Null.
Argument
dt
Optional positional argument: a reference to a data table. If this argument is not in the form of an assignment, then it is considered a data table expression.
script
Any valid JSL expressions.
Example
The following example creates data table references and then iterates over each row in Big Class.jmp. If the value of age in a row is greater than 15, the age is printed to the log.
For Each Row( dt, If( :age > 15, Show( :age ) ) );
If(condition1, result1, <condition2, result2,> ..., <elseResult>)
Description
Evaluates the first of each pair of arguments and returns the evaluation of the result expression associated with the first condition argument that evaluates to a nonzero result. The condition arguments are evaluated in order. If all of the condition arguments evaluate to zero, the optional elseResult is evaluated and the result is returned. If no elseResult is specified, and none of the conditions are true, a missing value is returned. If all of the condition arguments evaluate to missing, a missing value is returned.
IfMax(expr1, result1, expr2, result2, ... <all missing result>)
Description
Evaluates the first of each pair of arguments and returns the evaluation of the result expression (the second of each pair) associated with the maximum of the expressions. If more than one expression is the maximum, the first maximum is returned. If all expressions are missing and a final result is not specified, missing is returned. If all expressions are missing and a final result is specified, that final result is returned. The test expressions must evaluate to numeric values, but the result expressions can be anything.
Returns
The result expression associated with the maximum of the expressions
IfMin(expr1, result1, expr2, result2, ... <all missing result>)
Description
Evaluates the first of each pair of arguments and returns the evaluation of the result expression (the second of each pair) associated with the minimum of the expressions. If more than one expression is the minimum, the first minimum is returned. If all expressions are missing and a final result is not specified, missing is returned. If all expressions are missing and a final result is specified, that final result is returned. The test expressions must evaluate to numeric values, but the result expressions can be anything.
Returns
The result expression associated with the minimum of the expressions
IfMZ(condition1, result1, <condition2, result2,> ..., <elseResult>)
Description
Evaluates the first of each pair of arguments and returns the evaluation of the result expression associated with the first condition argument that evaluates to a nonzero result. The condition arguments are evaluated in order. If all of the condition arguments evaluate to zero or missing, the optional elseResult is evaluated and the result is returned. If no elseResult is specified, and none of the conditions are true, a missing value is returned.
Notes
The test arguments are evaluated in order until the first nonzero result. If all test results return zero or missing, the elseExpr argument is evaluated.
IfMZ() is equivalent to If() where missing values for evaluated condition arguments are treated as zero.
Interpolate(x, x1, y1, x2, y2)
Interpolate(x, xmatrix, ymatrix)
Description
Linearly interpolates the y-value corresponding to a given x-value between two points (x1, y1), and (x2, y2) or by matrices xmatrix and ymatrix. The points must be in ascending order.
Is Associative Array(name)
Description
Returns 1 if the evaluated argument is an associative array, or 0 otherwise.
Is Empty(global)
Is Empty(dt)
Is Empty(col)
Description
Returns 1 if the global variable, data table, or data column is undefined or holds the Empty() value, or 0 otherwise.
Is Expr(x)
Description
Returns 1 if the evaluated argument is an expression, or 0 otherwise.
Is List
See Is List(x).
Is Name(x)
Description
Returns 1 if the evaluated argument is a name, or 0 otherwise.
Is Namespace(namespace)
Description
Returns 1 if the namespace argument is a namespace; returns 0 otherwise.
Is Number(x)
Description
Returns 1 if the evaluated argument is a number or missing numeric value, or 0 otherwise.
Is Scriptable(x)
Description
Returns 1 if the evaluated argument is a scriptable object, or 0 otherwise.
Is String(x)
Description
Returns 1 if the evaluated argument is a string, or 0 otherwise.
Match(x, value1, result1, value2, result2, ..., resultElse)
Description
If a is equal to value1, then result1 is returned. If a is equal to value2, result2 is returned, and so on.
Note
The Match() function explicitly checks to see if the compare expression x is missing and if the value of value1 is missing, then it returns the value of result1; otherwise it continues to compare the expression x to each valueN value in each valueN/resultN pair, ignoring any missing values. If the expression x is equal to any of the valueN value, then the corresponding resultN value is returned. If no matching valueN value is found, then the resultElse value is returned.
MatchMZ(x, value1, expr1, value2, expr2, ..., exprElse)
Description
Evaluates and returns the exprN argument that equals x or evaluates and returns the exprElse argument if no value equals x.
Note
The MatchMZ() function works the same as the Match() function except that missing values are treated as 0.
Not(a)
!a
Description
Logical Not.
Returns
0 (false) if a>0.
1 (true) if a<=0.
Missing value if a is missing.
Argument
a
Any variable or number. The variable must have a numeric or matrix value.
Notes
Mostly used for conditional statements and loop control.
Or(a, b)
a|b
Description
Logical Or.
Returns
1 (true) if either of or both a and b are true.
0 (false) otherwise.
Missing if either are missing.
Arguments
a, b
Notes
OrMZ(a, b)
a :| b
Description
Returns the logical OR of all arguments with missing values treated as zeroes: 1 if any arguments are nonzero and 0 otherwise.
Returns
Arguments
a, b
Notes
Mostly used for conditional statements and loop control. When opening a JMP 3 data table, this function is automatically used for any Or function.
Or() returns missing if any evaluated argument is missing. OrMZ() returns 0 if any evaluated argument is missing.
Return(<Expr1>, <Expr2>, ..., <ExprN>)
Description
Returns an expression value from a user-defined function.
Example
This example returns the evaluation of both expressions in the Return() function as a list. The Return() function can have more than one argument. If only one is present, then the value of the expression is returned. If more than one is present, then the values of all the expressions is returned in a list.
f = Function( {a, b},
	Return( a - b, a + b )
{lo, hi} = f( 10, 1 );
Show( lo, hi );
Show( f( 7, 15 ) );
lo = 9;
hi = 11;
f(7, 15) = {-8, 22};
Note
Return() not enclosed by a function, method, or recursive function call causes an error.
Step(x0, x1, y1, x2, y2, ...)
Step(x0, [x1, x2, ...], [y1, y2, ...])
Description
Returns the y argument corresponding to the largest x argument that is less than or equal to x0. The x points must be specified in ascending order.
Stop()
Description
Immediately stops a script that is running.
While(expr, body)
Description
Repeatedly tests the expr condition and executes the body until the expr condition is no longer true.
Zero Or Missing(expr)
Description
Returns 1 if expr yields a missing value or zero, 0 otherwise.
