Using JMP > Formula Editor > Edit Formulas > Correct Mistakes
Publication date: 07/30/2020
Correct Mistakes
If you make a mistake while entering a formula, hold down the Ctrl key and press Z. This reverses the effect of the last (undo-able) command.
Other commands to help modify formulas include the following:
Click the delete button () on the Formula Editor keypad to remove the selected expression.
Use the cut, copy, and paste keyboard shortcut commands or right-click a highlighted part of the formula and select Cut, Copy, or Paste from the menu.
Drag portions of the formula to rearrange them.
