Basic Analysis > Contingency Analysis > Correspondence Analysis > Correspondence Analysis Options
Publication date: 07/30/2020
Use the options in the red triangle menu next to Correspondence Analysis to produce a 3-D scatterplot and add column properties to the data table.
3D Correspondence Analysis
Produces a 3-D scatterplot.
Save Value Ordering
Takes the order of the levels sorted by the first correspondence score coefficient and makes a column property for both the X and Y columns.
