Publication date: 07/30/2020
Counts per Unit Calculator
Use the Counts per Unit Calculator to evaluate sample size for a one-sided hypothesis test about the defects (counts) per unit. Sample size and power are associated with the following hypothesis test:
versus a one-sided alternative:
where λ is the rate of a Poisson distribution.
