Publication date: 07/30/2020
Delete Properties
To delete the same properties across multiple columns
1. Select the columns containing the attributes or properties that you want to delete.
2. Select Cols > Standardize Attributes.
3. Under Delete Properties, click Column Properties and select the properties that you want to delete.
4. Click OK.
Note: Make sure you click OK and not Remove. Clicking Remove simply removes the property from the list, but does not delete it.
