Reliability and Survival Methods > Destructive Degradation > Destructive Degradation Platform Options
Publication date: 07/30/2020
The Degradation Data Analysis red triangle menu contains the following options:
Graph Options
Provides options for modifying the platform graphs.
Shade
Turns the shading on or off. By default, the upper and lower bounds of each shaded band at a given value of time correspond to the 0.025 and 0.975 quantiles of the distribution of Y.
Shade Coverage
If shading is on, you can enter a proportion to increase or decrease the amount of shading coverage.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
