Publication date: 07/30/2020
Effective Resolution
The Effective Resolution report helps you determine how well your measurement increments are working. You might find that you need to add or drop digits when recording your measurements, or your current increments might be effective as is. Note the following:
The Probable Error calculates the median error of a measurement.
The Current Measurement Increment reflects how many digits you are currently rounding to and is taken from the data as the nearest power of ten. This number is compared to the Smallest Effective Increment, Lower Bound Increment, and Largest Effective Increment. Based on that comparison, a recommendation is made.
Large measurement increments have less uncertainty in the last digit, but large median errors. Small measurement increments have small median errors, but more uncertainty in the last digit.
