Design of Experiments Guide > Response Surface Designs > Example of a Response Surface Design
Publication date: 07/30/2020
In this example, you construct a Box-Behnken design for a tire tread experiment. Your objective is to match a target value of 450 for a measure of elongation (Stretch). The stretch varies as a function of the amounts of Silica, Silane, and Sulfur used to manufacture the tire tread compound. You want to experiment over a wide range of factor settings to find the settings that achieve the target.
Construct a Box-Behnken Design
Analyze the Experimental Data
Explore Optimal Settings
