Predictive and Specialized Modeling > Matched Pairs Analysis > Example of Comparing Matched Pairs
Publication date: 07/30/2020
This example uses the Therm.jmp sample data table. The data contains temperature measurements on 20 people. Temperature is measured using two types of thermometers: oral and tympanic (ear). You want to determine whether the two types of thermometers produce equal temperature readings. Note that the differences in temperature between the different people are not important. The matched pairs analysis is testing the differences between the thermometers.
1. Select Help > Sample Data Library and open Therm.jmp.
2. Select Analyze > Specialized Modeling > Matched Pairs.
3. Select Oral and Tympanic and click Y, Paired Response.
4. Click OK.
The report window appears.
Figure 19.2 The Matched Pairs Report Window
The results show that, on average, the tympanic thermometer measures 1.12 degrees higher than the oral thermometer. The small p-value (Prob > |t|) indicates that this difference is statistically significant, and not due to chance.
Note that this matched pairs analysis does not indicate which thermometer is correct (if either), but indicates only that there is a difference between the thermometers.
