Fitting Linear Models > Model Specification > Examples of Model Specifications and Their Model Fits
Publication date: 07/30/2020
This section gives templates for entering the effects for various model types that you can specify using the Construct Model Effects panel in the Fit Model platform.
The model effects X and Z represent continuous columns.
The model effects A, B, and C represent nominal or ordinal columns.
For most models, visual views of their model fits are also given.
Simple Linear Regression
Polynomial in X to Degree k
Polynomial in X and Z to Degree k
Multiple Linear Regression
One-Way Analysis of Variance
Two-Way Analysis of Variance
Two-Way Analysis of Variance with Interaction
Three-Way Full Factorial
Analysis of Covariance, Equal Slopes
Analysis of Covariance, Unequal Slopes
Two-Factor Nested Random Effects Model
Three-Factor Fully Nested Random Effects Model
Simple Split Plot or Repeated Measures Model
Two-Factor Response Surface Model
Knotted Spline Effect
