Profilers > Excel Profiler
Publication date: 07/30/2020
Excel Profiler
Visualize Models Saved in Microsoft Excel
The JMP Add-In for Excel uses the JMP Profiler to visualize models (or formulas) stored in Excel worksheets. You can install the Excel add-in when you install JMP.
Figure 9.1 Example of a Prediction Profiler Using an Excel ModelĀ
Contents
Overview of the Excel Profiler
Example of an Excel Model
Run the JMP Profiler
Use Linear Constraints
Resolution of Profile Lines
Use the Excel Profiler from JMP
