Publication date: 07/30/2020
Explore Missing Values Utility Options
ADI Loading Matrix
(Available only for the ADI utility.) Shows or hides a report that contains the columns that correspond to the factor loading for each component.
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
Save By-Group Script
