Some features in JMP are coded to take advantage of multiple central processing units (CPUs) on a machine, allowing these features to run significantly faster. This process is called multithreading.
The following features support multithreading:
• Boosted Trees
• Bootstrap Forest
• Choice
• Covering Arrays
• Capability Analysis in Distribution
• Factor Analysis
• Fit Life by X
• Fit Model: Parametric Survival, Mixed Model, Generalized Regression, and Response Screening
• Functional Data Explorer
• Gaussian ( Fast GASP and the use of Categorical variables are only in JMP Pro.)
• Latent Class Analysis
• Life Distribution
• Multivariate
• Neural ( Some features are only in JMP Pro.)
• Nominal Logistic
• Nonlinear and Nonlinear Curve
• Normal Mixtures in Cluster Analysis
• Partial Least Squares ( Some features are only in JMP Pro.)
• Partition
• Predictor Screening
• Principal Components
• Process Screening
• Profiler (Does not apply to Profilers launched from within other platforms.)
• Reliability Forecast
• Repairable Systems Simulation
• Response Screening
• Sparse Principal Components
• Structural Equation Models
• Support Vector Machiines
• SVD Imputation in the Missing Values Screening
• Text Explorer ( SVD and Latent Class Analysis are only in JMP Pro.)
• Time Series Forecast
• Uplift
• Variable Clustering
