Publication date: 07/30/2020
Fit the Model
1. Select Help > Sample Data Library and open Design Experiment/Extraction 3 Data.jmp.
2. Select DOE > Definitive Screening > Fit Definitive Screening.
3. Select Yield and click Y.
4. Select Lot through Time and click X.
5. Click OK.
The fit performs a two-stage analysis. For more information about the algorithm, see Technical Details for the Fit Definitive Screening Platform.
