Basic Analysis > Bivariate Analysis > Fitting Options
Publication date: 07/30/2020
Fitting Options
Note: The Fit Group menu appears if you have specified multiple Y or multiple X variables. Menu options enable you to arrange reports or order them by RSquare. See Fit Group Options in Fitting Linear Models.
The Bivariate Fit red triangle menu contains display options, fitting options, and control options.
Show Points
Hides or shows the points in the scatterplot. A check mark indicates that points are shown.
Histogram Borders
Attaches histograms to the x- and y-axes of the scatterplot. A check mark indicates that histogram borders are turned on. See Histogram Borders.
Note: When you apply only the Hidden row state to rows in the data table, the corresponding points do not appear in the scatterplot. However, the histograms are constructed using the hidden rows. If you want to exclude rows from the construction of the histograms and from analysis results, apply the Exclude row state and select Redo > Redo Analysis from the Bivariate red triangle menu.
Summary Statistics
Shows the summary statistics for the plot, such as the correlation and confidence intervals, mean, and standard deviation.
Group By
Lets you select a classification (or grouping) variable. A separate analysis is computed for each level of the grouping variable, and regression curves or ellipses are overlaid on the scatterplot. See Group By.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
