The following conventions help you relate written material to information that you see on your screen:
• Sample data table names, column names, pathnames, filenames, file extensions, and folders appear in Helvetica (or sans-serif online) font.
• Code appears in Lucida Sans Typewriter (or monospace online) font.
• Code output appears in Lucida Sans Typewriter italic (or monospace italic online) font and is indented farther than the preceding code.
• Helvetica bold formatting (or bold sans-serif online) indicates items that you select to complete a task:
– buttons
– check boxes
– commands
– list names that are selectable
– menus
– options
– tab names
– text boxes
• The following items appear in italics:
– words or phrases that are important or have definitions specific to JMP
– book titles
– variables
• Features that are for JMP Pro only are noted with the JMP Pro icon . For an overview of JMP Pro features, visit https://www.jmp.com/software/pro/.
Note: Special information and limitations appear within a Note.
Tip: Helpful information appears within a Tip.
