Here are pictures of many of the graphs that you can create with JMP. Each picture is labeled with the platform used to create it. For more information about the platforms and these and other graphs, see the documentation on the Help > Books menu.
Histogram Analyze > Distribution |
Bivariate Analyze > Fit Y by X |
Oneway Analyze > Fit Y by X |
Oneway t Test Analyze > Fit Y by X |
Logistic Analyze > Fit Y by X |
Mosaic Plot Analyze > Fit Y by X |
Matched Pairs Analyze > Specialized Modeling > Matched Pairs |
Leverage Plot Analyze > Fit Model |
LS Means Plot Analyze > Fit Model |
MANOVA Analyze > Fit Model |
Partition Analyze > Predictive Modeling > Partition |
Neural Diagram Analyze > Predictive Modeling > Neural |
Actual by Predicted Analyze > Predictive Modeling > Model Comparison |
Nonlinear Fit Analyze > Specialized Modeling > Nonlinear |
Surface Profiler Analyze > Specialized Modeling > Gaussian Process |
Time Series Analyze > Specialized Modeling > Time Series |
Screening Analyze > Specialized Modeling > Specialized DOE Models > Fit Two Level Screening |
FDR pValue Plot Analyze > Screening > Response Screening |
Scatterplot Matrix Analyze > Multivariate Methods > Multivariate |
Dendrogram Analyze > Clustering > Hierarchical Cluster |
Self Organizing Map Analyze > Clustering > K Means Cluster |
Principal Components Analyze > Multivariate Methods > Principal Components |
Canonical Plot Analyze > Multivariate Methods > Discriminant |
Loadings Plot Analyze > Multivariate Methods > Partial Least Squares |
XBar and R Charts Analyze > Quality and Process > Control Chart Builder |
Average Chart Analyze > Quality and Process > Measurement Systems Analysis |
Variability Chart Analyze > Quality and Process > Variability/Attribute Chart |
Goal Plot Analyze > Quality and Process > Process Capability |
Individual Measurement Chart Moving Range Chart Analyze > Quality and Process > Control Chart > IR |
XBar Chart Analyze > Quality and Process > Control Chart > XBar |
Pareto Plot Analyze > Quality and Process > Pareto Plot |
Ishikawa Chart Fishbone Chart Analyze > Quality and Process> Diagram |
Compare Distributions Analyze > Reliability and Survival > Life Distribution |
Nonparametric Overlay Analyze > Reliability and Survival > Fit Life by X |
Scatterplot Analyze > Reliability and Survival > Fit Life by X |
MCF Plot Analyze > Reliability and Survival > Recurrence Analysis |
Overlay Analyze > Reliability and Survival > Degradation |
Prediction Interval Analyze > Reliability and Survival > Destructive Degradation |
Forecast Analyze > Reliability and Survival > Reliability Forecast |
Piecewise Weibull NHPP Analyze > Reliability and Survival > Reliability Growth |
Reliability Block Diagram Analyze > Reliability and Survival > Reliability Block Diagram |
Failure Plot Analyze > Reliability and Survival > Survival |
Survival Quantiles Analyze > Reliability and Survival > Fit Parametric Survival |
Baseline Survival Analyze > Reliability and Survival > Fit Proportional Hazards |
Mixture Profiler Analyze > Consumer Research > Categorical |
Factor Loading Plot Analyze > Multivariate Methods > Factor Analysis |
Prediction Profile Analyze > Consumer Research > Choice |
Characteristic Curves Analyze > Multivariate Methods > Item Analysis |
Multiple Correspondence Analysis Analyze > Multivariate Methods > Multiple Correspondence Analysis |
Uplift Model Analyze > Consumer Research > Uplift |
Dual Plot Analyze > Multivariate Methods > Item Analysis |
Line Graphs Graph > Graph Builder |
Box Plots Graph > Graph Builder |
Stacked Bar Chart Graph > Graph Builder |
Pie Chart Graph > Graph Builder |
Needle and Line Chart Graph > Graph Builder |
Smoother Graph > Graph Builder |
Three Dimensional Scatterplot Graph > Scatterplot 3D |
Contour Plot Graph > Graph Builder |
Bubble Plot Graph > Bubble Plot |
Parallel Plot Graph > Graph Builder |
Cell Plot Graph > Cell Plot |
Treemap Graph > Graph Builder |
Scatterplot Matrix Graph > Scatterplot Matrix |
Ternary Plot Graph > Ternary Plot |
Prediction Profiler Graph > Profiler |
Contour Profiler Graph > Contour Profiler |
Surface Plot Graph > Surface Plot |
Mixture Profiler Graph > Mixture Profiler |
Multidimensional Scaling Analyze > Multivariate Methods > Multidimensional Scaling |
MaxDiff Analyze > Consumer Research > MaxDiff |
Stress Patterns Plot Analyze > Reliability and Survival > Cumulative Damage |
Repairable Systems Simulation Analyze > Reliability and Survival > Repairable Systems Simulation |
Latent Class Analysis Analyze > Clustering > Latent Class Analysis |
Predictor Screening Analyze > Screening > Predictor Screening |
Process Screening Analyze > Screening > Process Screening |
Text Explorer Analyze > Text Explorer |
Multiple Factor Analysis Analyze > Consumer Research > Multiple Factor Analysis |
Model Driven Multivariate Control Chart Analyze > Quality and Process Methods > Model Driven Multivariate Control Chart |
Structural Equation Models Analyze > Multivariate Methods > Structural Equation Models |
Support Vector Machines Analyze > Predictive Modeling > Support Vector Machines |
