Predictive and Specialized Modeling > Gaussian Process > Gaussian Process Platform Options
Publication date: 07/30/2020
The Gaussian Process red triangle menu contains the following options:
Profiler
Opens the standard Profiler. See Profiler in Profilers.
Contour Profiler
Opens the Contour Profiler. See Contour Profiler in Profilers.
Surface Profiler
Opens the Surface Profiler. See Surface Plot in Profilers.
Save Prediction Formula
Creates a new prediction formula column in the active data table.
Save Variance Formula
Creates a new variance formula column in the active data table.
Publish Prediction Formula
Creates a prediction formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot.
Publish Variance Formula
Creates a variance formula and saves it as a formula column script in the Formula Depot platform. If a Formula Depot report is not open, this option creates a Formula Depot report. See Formula Depot.
Save Jackknife Predicted Values
Saves the jackknife predicted values to the active data table. These are the X-axis values for the Actual by Predicted Plot.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
