Discovering JMP > Work with Your Data > Get Your Data into JMP
Publication date: 07/30/2020
To copy and paste data from another application, see Copy and Paste Data.
To import data from another application, see Import Data.
To enter data directly into a data table, see Enter Data
To open a data table, double-click the file, or use the File > Open command.
You can also import data into JMP from a database. See Import Data from a Database in Using JMP.
This chapter uses sample data tables and sample import data that is installed with JMP. To find these files, see Using Sample Data in the Introducing JMP section.
