Design of Experiments Guide > Group Orthogonal Supersaturated Designs
Publication date: 07/30/2020
Create Group Orthogonal Supersaturated Designs
Group orthogonal supersaturated designs are a special case of screening designs. They are appropriate in early stage work when the number of factors to be investigated is larger than the number of feasible runs. A supersaturated design is a design with fewer observations than model parameters. That is, the design cannot estimate all main effects simultaneously. This makes detection of significant effects difficult. A group orthogonal supersaturated design is a special class of two-level supersaturated designs with properties that are desirable for model selection.
Contents
Overview of Group Orthogonal Supersaturated Designs
Example of Group Orthogonal Supersaturated Designs
Launch the Group Orthogonal Supersaturated Designs Platform
Group Orthogonal Supersaturated Design Window
Specify Factors, Structure, and Make Design
Verify Design and Make Table
Group Orthogonal Supersaturated Design Options
Statistical Details for Group Orthogonal Supersaturated Designs
