Publication date: 07/30/2020
Group Summary of Y
The report contains a summary table for each Y variable. The summaries contain the following information for each time series:
Series
The level of the grouping variable that defines the individual series.
Min
The minimum value of Y for the individual series.
Max
The maximum value of Y for the individual series.
Length
The duration of the series. This is determined based on the starting and ending time stamps and the result of the Analysis of Time Pattern.
N Obs
The number of observations. If there are no missing records, this number is the same as the Length.
N Missing
The number of missing Y values.
All Positive
Indicates whether all of the Y values are positive.
Comment
Indicates if there is a problem with the series, such as non-unique time stamps.
