Multivariate Methods > Hierarchical Cluster > Hierarchical Cluster Report
Publication date: 07/30/2020
The Hierarchical Cluster report displays the method used, a dendrogram, and the Clustering History table. If you assigned a column as a Label in the launch window, the column’s values identify each observation in the dendrogram.
Dendrogram Report
Illustration of Dendrogram and Distance Graph
Clustering History Report
