Using JMP > Import Your Data > Import Data from SAS
Publication date: 07/30/2020
You can connect to a SAS server and work directly with SAS data sets.
Java Runtime Environment (JRE) Requirements
On Windows, Java Runtime Environment (JRE) 7 or later must be installed on your computer to access SAS. However, JRE 7 does not need to be specified as the current version.
On macOS, JRE 7 or later must be installed for SAS integration.
Note: On Windows, the bitness of the JRE must match that of JMP. For example, 64-bit JMP communicates with both 32-bit and 64-bit SAS if the 64-bit JRE is installed.
