Publication date: 07/30/2020
K Means Report
When you click Go in the Control Panel, the following reports appear:
A Cluster Comparison report. See Cluster Comparison Report.
One or more K Means reports. The reports are dynamically named K Means NCluster=<k> depending on, k, the number of clusters fit. A K Means NCluster=<k> report appears for each fit that you conduct.
The Cluster Comparison report and the KMeans NCluster=11 report for the Cytometry.jmp data table, with the variables CD3 through MCB as Y, Columns, are shown in Figure 13.2 and K Means NCluster=11 Report.
