Profilers > Contour Profiler > Launch the Contour Profiler Platform
Publication date: 07/30/2020
The Contour Profiler can be accessed in the following ways:
The Contour Profiler can be accessed directly from the Graph menu. When you access the Contour Profiler in this way, the Contour Profiler launch window appears. See Profiler Launch Windows in the Introduction to Profilers section.
The Contour Profiler can be accessed as a red triangle menu option in many modeling platforms. See Where to Find JMP Profilers in the Introduction to Profilers section for more information about the availability of the Contour Profiler in different platforms.
The Contour Profiler can be accessed from the Model Comparisons platform. Select Profiler from the Model Comparisons red triangle menu. Then, select Contour Profiler from the Profiler red triangle menu.
The Contour Profiler can be accessed from the Formula Depot platform. Select Profiler from the Formula Depot red triangle menu and select the models to be profiled. Then, select Contour Profiler from the Profiler red triangle menu.
