Quality and Process Methods > Legacy Control Charts
Publication date: 07/30/2020
Create Variable and Attribute Control Charts
A control chart is a graphical and analytic tool for monitoring process variation. The natural variation in a process can be quantified using a set of control limits. Control limits help distinguish common-cause variation from special-cause variation. Typically, action is taken to identify and eliminate special-cause variation. It is also important to quantify the common-cause variation in a process, as this determines the capability of a process.
The legacy control chart platforms in JMP provide a variety of control charts, as well as runs charts and V-Mask CUSUM charts. To support process improvement initiatives, most of the control chart options display separate control charts for different phases of a project on the same chart.
Figure 12.1 Control Chart Example
Contents
Example of a Legacy Control Chart
Legacy Control Chart Types
Control Charts for Variables
Control Charts for Attributes
Launch a Legacy Control Chart Platform
Process Information
Limits Specifications
Specified Statistics
Legacy Control Chart Reports
V-Mask CUSUM Chart Reports
Interpret a Two-Sided V-Mask CUSUM Chart
Interpret a One-Sided CUSUM Chart
Legacy Control Chart Platform Options
Window Options for Legacy Control Charts
Chart Options for Legacy Control Charts
Chart Options for V-Mask CUSUM Control Charts
Saving and Retrieving Limits
Excluded, Hidden, and Deleted Samples
Additional Examples of the Control Chart Platform
Runs Chart Example
XBar Chart and R Chart Example
XBar and S charts with Varying Subgroup Sizes Example
Individual Measurement and Moving Range Charts Example
P Chart Example
NP Chart Example
C Chart Example
U Chart Example
Presummarize Chart Example
V-Mask CUSUM Chart Example
One-Sided CUSUM Chart Example
Phase Example
Statistical Details for the Control Chart Platform
Control Limits for Median Moving Range Charts
Statistical Details for Capability Analysis
Statistical Details for V-Mask CUSUM Control Charts
