Fitting Linear Models > Loglinear Variance Models > Loglinear Platform Options
Publication date: 07/30/2020
The Loglinear Variance Fit menu contains the following options:
Save Columns
Creates one or more columns in the data table. See Save Columns.
Row Diagnostics
Plots row diagnostics. See Row Diagnostics.
Profilers
Opens the Profiler, Contour Profiler, or Surface Profiler. See Factor Profiling in the Standard Least Squares Report and Options section.
Model Dialog
Shows the completed launch window for the current analysis.
See Local Data Filter, Redo Menus, and Save Script Menus in Using JMP for more information about the following options:
Local Data Filter
Redo
Save Script
Save By-Group Script
