Publication date: 07/30/2020
Make Table
Click Make Table to construct the table or tables that you selected in Output Options. In the table panel of the Choice Profiles table, there is a Choice script. Run the script and then click Run Model to analyze your experimental results.
For information about the Choice Model report, see Choice Model Report in Consumer Research.
