Predictive and Specialized Modeling > Make Validation Column > Make Validation Column Platform Options
Publication date: 07/30/2020
The Make Validation Column Utility has the following red triangle menu options:
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
