Publication date: 07/30/2020
Manage Spec Limits Options
In the window where you set specification limits, there are buttons to save and load specification limits, and options in the red triangle menu next to Manage Spec Limits.
Buttons
Load from Limits Table
Loads specification limits from a JMP data table.
Save to Column Properties
Saves the specification limits as column properties in the associated data table.
Save to Spec Limits Table (Wide or Tall)
Saves the specification limits to a new data table in a wide or tall format.
Red Triangle Options
Show Limits All
Selects boxes under Show Limits for all of the columns. If Show Limits is selected for a column, the Show as Graph Reference Lines option is selected in the Spec Limits column property. The Show as Graph Reference Lines option displays the specification limits and target that you specify as reference lines in select analysis plots.
Note: If all boxes under Show Limits are selected, the Show Limits All option deselects all of the boxes under Show Limits.
Round Decimals
Sets the number of decimal places to which you want the specification limits rounded.
Color Out of Spec Values
Colors any values in the data table that are outside the specification limits for the columns.
See Redo Menus and Save Script Menus in Using JMP for more information about the following options:
Redo
Save Script
