Design of Experiments Guide > Mixture Designs > Mixture Design Window
Publication date: 07/30/2020
The mixture design window updates as you work through the design steps. See The DOE Workflow: Describe, Specify, Design. The workflow and outlines vary depending on design type.
Figure 13.2 Mixture Design Workflow
