Essential Graphing > Ternary Plots > The Ternary Plot > Mixtures and Constraints
Publication date: 07/30/2020
Ternary Plot uses the Mixture column property to shade the portion of the graph that is out of bounds. The Ternary plot recognizes the mixture sum, mixture bounds, and general linear constraints. For information about setting the Mixture column property in the Column Info window, see Mixture in Using JMP.
Related Information
Example Using Mixture Constraints
