Publication date: 07/30/2020
Model Fit Report
A report is created for each fitted model. The red triangle menu for each model report contains the following options.
Prediction Model
Gives the algebraic form of the prediction formula and the parameters.
Summary of Fit
Gives the same fit statistics as the Model Comparison report.
Parameter Estimates
Gives the estimates of the parameters, standard errors, Chi-squared statistics, p-values, and confidence intervals. The correlations and covariances of the estimates are given also.
Tip: You can sort the Parameter Estimates report table by clicking on the column that you want to sort by.
Plot
Gives plots of the data with the fitted model (Figure 13.7). The plots are shown only when you select a Grouping variable on the platform launch window.
