Publication date: 07/30/2020
Model Options
After you click Run, a Structural Equation Model report for the specified model appears. This report has a red triangle menu that contains the following options:
Path Diagram
Contains options to modify the path diagram. See Path Diagram.
Summary of Fit
Shows or hides a report that contains details of the model fit.
Parameter Estimates
Shows or hides a report that contains the unstandardized parameter estimates for the model.
Standardized Parameter Estimates
Shows or hides a report that contains the standardized parameter estimates for the model.
Model Implied Covariances
Shows or hides a report that contains the covariance matrix that is implied by the model.
Model Implied Means
Shows or hides a report that contains the means for each variable that are implied by the model.
Residuals
Shows or hides a report that contains a matrix of the residuals for the model. This matrix is the difference between the model implied covariance matrix and the sample covariance matrix.
Normalized Residuals
Shows or hides a report that contains a matrix of the normalized residuals for the model.
Normalized Residuals Heat Map
Shows or hides a report that contains a heat map of the normalized residuals for the model.
RAM Matrices
Shows or hides a report that contains the model matrices used in reticular action model (RAM) notation.
Covariance of Estimates
Shows or hides a report that contains the covariance matrix of the parameter estimates for the model.
Modification Indices
Shows or hides a report that contains the estimates of model modification indices. These values can be used to determine which parameters might be added to the model to improve model fit.
Save Factor Scores
(Available only when there are latent variables in the model.) Saves a column with the factor score for each variable to columns in the data table. The factor scores are calculated in a hidden column that is also added to the data table. This hidden column uses the Estimate Factor Scores() JSL function. For more information about this function, see Help > Scripting Index.
Recall in Model Specification
Sets the model in the Model Specification report to the specified model.
Remove Fit
Removes the specified model report from the report window.
